Exhaust options
One of my favorites, especially if your riding a passenger, is the Patriot Defenders. It is an awesome sounding exhaust, that you can adjust the tone. The one for the soft tail Harley will fit your 04.
Which exhaust goes down close to rear cylinder and has end facing out away from bike ? I’ve seen a couple pics of those on here also
Here’s a few softail exhausts on fleabay. Do the shorter straight pipes like LAF make it run poorly or need carb adjustments ? And would 2” or 1 3/4” be better ?
I’m looking for something cheap bc I don’t ride much.
knothead
Those laf pipes im not a big fan of them...one reason is they blow straight down on the ground and make a dusty ass mess....another reason is the will burn your legs while setting at a stop light...this is just my opinion some folks here like those exhaust...
Go check out at bigdogpartskingpin.com and look at the blow exhaust....Mick posted a pic of them on his orange bike...those exhaust sound good and perform fine...i put a set of them on one of my bikes...
Mickmorris
Well Known Member
If your super G has stock jets you would likely need to change them with those straight pipes. Also get torque cones for back pressure.
I do like the look of those but I’m not looking to spend $800-1000.
