Bigdog Ridgeback
What are the dimensions for a battery on a 2004 ridgeback?
Buy a Deka ETX-20L
Don't screw with odd ball brands that claim exceedingly higher than normal CCA -- they LIE.
Buy a Deka ETX-20L
Well truth be told, I'd bet you don't have the setup to properly test the CCA and with the average test equipment used that would be a guess (which often I have found to be wrong). To truly test CCA you need to leave the battery at 0 degrees for 24hrs then test cranking current.I am looking at them, i had a Drag specialties in it and believe or not it lasted 6 years , it was claimed to rated at 320 cca but when I had it tested today I was showing only 260 cca
