SS carburetor
VonDamage
Hey guys I took SS cover off carburetor oil shoots out of a hole left side of carb every time motor turns over little help please thanks in advance
bruce
We'll need more info if you want help, what year big dog which type of s&s carburetor and pictures maybe of where the oils actually coming from, just to start with.
VonDamage
Thanks already left my kids shop 2001 mastiff hole left side of air intake take SS cover off sguifs oil out of hole about 1/8 inch big looks like line goes to crankI mean you turn it over and it shoots two feet away from the bike
DynoDave
Chris a big dog said it’s been sitting to long all the oil from the bag has drained down into the crank case needs to be let out
Yep, sounds like it's 'wet sumping'. After sitting for weeks or months without being run oil from the oil bag will seep past the check ball in the oil pump and go into the crankcase. Mine would do this after 2-3 weeks of sitting idle. Many guys run their breather hose under the bike instead of to the carb. Just be sure it's not splooging oil on the ground before riding. Could get on your back tire and make for some squirrely riding! Ask me how I know!
VonDamage
Thanks Dyno guess I need to drain oil let it sit few days start from scratch with oil change It just sits so low I’m having to but a fork life under it to get a place to let crank oil out any other suggestions
Make sure you dont loosen the set screw on the bottom of the cases. Not necessary. Grab a Scavenger for ur oil changes. Gets ALL the old oil out the motor.
Mickmorris
Well Known Member
Picture of the bike. From carb side
