Congratulations Brother! Welcome to the Dog Pound! Beautiful bike! Look forward to riding with you someday!!
Completely true, I did notice I could lean it over WAY more vs. my XL, it was a bit jarring at first... but nothing some more seat time won't handle!You will find that a good lean will get ya thru the corners a bit easier. Its amazing just how far over these Pits will go before scraping. Enjoy the pup.
Thank you! I do indeed look forward to hopefully meeting up with all of you in the near future, it would be awesome to let her run with some other Big Dogs- gotta keep her exercised! LolCongratulations Brother! Welcome to the Dog Pound! Beautiful bike! Look forward to riding with you someday!!![]()
Congratulations! That's a great story! If you are thinking about installing a mikuni on your pitbull, I would swap the 45 from your sporty and get a 42 for it when you get it up and running again. The 42 is more than capable of handling the most highly modified sportster engines. Bottom end torque should increase significantly and fuel mileage may improve too. Installing a mikuni on a big dog requires a few mods, but nothing major. IMO, it is definitely an upgrade.Now feels as good a time as any to share the things she's going to need in the future, as well as some future improvements I would like to make. This isn't in any particular order, but as mentioned before, tires and compression releases are the first up.
Known issues at this time- not a total list, just the things I know right off the top of my head:
Tires
Left fuel cap (missing the chrome top, the bottom insert is still secure in the filler.)
Speedometer has a small gremlin- it will sometimes stick at 120mph after/during the initial gauge sweep when cycling the key. The next key cycle seems to normalize the speedo, so some further testing is needed. It was stuck at 120 on the test ride, so I don't know for certain if it truly works when it goes back to 0 yet.
Future improvements:
Compression releases- this is an '03, so the heads should have provisions for adding them already.
Push-up seat- I may have to have this custom made since I haven't actually seen one for an '03 yet. This is more of a comfort/preference thing than anything, I can reach the forwards ok, just feels like I should be sitting a bit more forward.
Mikuni HSR45 or HSR48- I have an HSR45 on my XL and I love the way it responds vs the Super G, much less the Harley CV carbs. This is not 100% set in stone, but just a possible future upgrade.
Anyhow, that's it for now. I'll have to wait until she's at home this week to give her a total inspection, but the broad strokes are there lol.
I have a set of gas tank caps off of my Vintage Sport Chopper that I would be glad to send to you if you could use them. Just say the word.Now feels as good a time as any to share the things she's going to need in the future, as well as some future improvements I would like to make. This isn't in any particular order, but as mentioned before, tires and compression releases are the first up.
Tires
This is a perfect example of what makes this forum an awesome place to be!I have a set of gas tank caps off of my Vintage Sport Chopper that I would be glad to send to you if you could use them. Just say the word. View attachment 97753View attachment 97754
Awesome post, thanks for all of the info!Welcome to the forum. Congrats on the new bike. It looks great and pretty much original. A couple of thoughts come to mind.
Keep in mind that the two fuel tank caps are different. One is right hand thread and the other is left hand thread. That may be why one cap cover is missing. Someone tried to remove it in the wrong direction and literally ripped it off the the tank
Another difference is that the right side cap is vented and the left side is not vented.
Those tanks are truly 2 separate tanks. To get a full fuel load you must fill both tanks.
There is a cross over line at the front of the tanks. It is like you say old enough to drink. Replace it. If it swells shut you will only get gas from the left tank
Those tanks have a liner in them from the factory. That liner,if origional, is not compatible with the alcohol in the gas we have today. Look inside the tank to see if the liner is peeling off the tank surface. If it is pieces of it will eventually block the ports where the hoses attach to.
Also there is a screen in the fuel shut off petcock. Check it for any debris such as dirt, rust or liner debris. We have seen instances where screens have been blocked and you ain't going anywhere that way.
Compression releases.,if you're heads are not machined for them don't worry about them. In fact if my heads were machined for them i would not go thru the headache and expense to install them. In my experience with my 107 it is my opinion that they are unnecessary if you keep a good battery fully charged with a tender, and have a good tune on you're engine you won't have any issues.
These are just some of the common issues we see here on the forum with the old enough to drink 2 tank Big Dog models. Some simple and inexpensive maintenance can avoid a ruined day of riding and a tow truck ride home. They are a different and rare breed for sure.
Good luck with you're work.,don't be afraid to ask questions here. Someone is always willing to help.
Frank
No trouble! About an hour or so south of Chicago, not too far from Benton Co., maybe 1-1.5 hr. Not horribly far at all.Not trying to be nosey or anything,, but where in Illinois are you located ? Anywhere close to Benton county Indiana ?
I thought about getting a No-Mar beforehand, but I am for certain now that I need some sort of tire machine here very soon!Good deal glad you got it going....yes the back tire is a pain to do by hand...ive done a bunch like that and i broke down and bought a no mar tire changer...
Sure hate your not going to get to come to our gathering but i understand....hopefully next year
Well the way i look at it is a brand new one can break down within 100 miles.... but i also understand what your saying at the same time....it does make someone feel better knowing a bike, car, etc little more before making a long trip...but again anything can happen at anytime....i normally just roll out anyway lol....No trouble! About an hour or so south of Chicago, not too far from Benton Co., maybe 1-1.5 hr. Not horribly far at all.
I would love to come, to be honest I am debating whether or not to try to make the ride anyway despite the laundry list of concerns... not the greatest idea, but a guy can have a flight-of-fancy now and again, right? Either way, still gotta get some good seat time next week to see if anything crops up lol.
