Chuck3d
A month or two ago I had my 2007 Bulldog running, but after sitting a few weeks, it wasn't starting, turning over or even giving me the fuel pump noise. The battery was fully charged and all I got on the EHC was the LED for air suspension turning on. I had tried the EHC reset procedure and everything else I could read on these forums. So I decided to go and get the EHC R.I.P. kit. I installed it last night and I'm 90% on my way to a running bike. Now I have all the lights working, engine cranks and I have the fuel pump pressuring up.
What I don't have is spark to the plugs. I have +12 volts running to the red wire of the ignition coil. But when I press the run button, that drops to ~ .12 volts. It may be that I'm using a digital meter and it's possible that the voltage is pulsing, but I'm not sure. I've tested the ignition ciols all the way back to the connector just outside the EFI controller and it stays ~ .12 volts.
Is there some input (like the crank position sensor) that the EFI controller needs to see to send the +12 volts to the ignition coil?
Can I test the crank position sensor by using a led and a 9V battery and seeing if the led lights when metal is passed in front of the sensor?
I'm already losing my hair, so pulling out more isn't helping. But any help you guys have would be more than appreciated!
