Should not ever drop below 10v when starting.What should the voltage initially drop to while starting the bike?
I dont have a charging issue (too high, too low), but Ill do as you said. I know this as Ive seen my voltage meter.
Note there is nothing between battery and voltmeter. My wiring is the bare minimum.
View attachment 93672Thank you.
Did you monitor voltage with one plug in?Disconnected the VR, one plug in. Still struggling to turn over. Switched plugs, same result. No plugs, spins like it should. Starter swap & green wire is next.
No response from starter is correct when green wire is disconnected so that's good.Did not watch voltmeter.
Reconnected VR, disconnected green wire. No response at all when the wire is disconnected. Had a friend turn the key while I pressed both CR's down. Rotated once then hung up.
Any other ides?
I thought you mentioned you just had a slam button to start it right there on your starter solenoid?Did not watch voltmeter.
Any other ides?
Good new battery should start with none or one compression releases working. You can hold one down with your finger and bike should start.Haybalor, I bought a new starter from Shovelheadkicker. Didnt make a difference.
Seems like the only time it hangs up is when the plugs are in. So I can only assume that there is some kinda issue with the CR's. So Im looking to go manual.
Well, if you replace the auto CR's with manual using the same location I think you're looking at burnt fingers very easily. I don't want to stick my fingers into the rocker box covers when the engine is hot and I need to restart! but your choice. I've had no problem with my auto crs.Hear ye hear ye! Found and fixed the problem...gremlin bell was gone. Put one on and she fired right up.
No, actually all I did was r&r the battery to the 420cca lithium. It hesitated like normal but powered past it. Didnt see any smoke from the connections. Still gonna switch to the manual CR's though. Thank you all for your time and knowledge. Im sorry we didnt figure out the problem. Once I do find it, Ill come back here to give closure to this thread.
As long as you checked and your charging system is in good shape you should be on your way to happiness !!!This a new lithium battery. Same model as couple years ago.
MMG6 420cca
