Needing to find something
Mastiff Rider64
I recently bought a Supertrapp 2 into 1 exhaust for my 06 Mastiff or 09 Bagger. It originally came off an 08 Mutt, but the seller didn't send the original mounting bracket for the 08 Mutt with it. I'm guessing here, but the 06 Mastiff is a 250 back tire, 09 Bagger is a 250 tire, the 08 Mutt 250 back tire, the mounting holes for the bracket seem to be very close to the same location on the Mastiff and Mutt bikes, but the 09 Bagger exhaust bracket holes are vertical so I know the bracket won't fit. But I am looking for the exhaust bracket for either a 04 Mastiff, 06 Mastiff or 08 Mutt. Anyone who has one that wouldn't mind parting with it let me know, or if you don't want to part with it but would allow me to borrow it to have one made please let me know. Thanks.
Here is a picture of what the exhaust looks like.
Mastiff Rider64
Shannon probably got what you need...if not i probably got one or 10, but i have to look and see what i got
Knot I talked to Shannon, he said he had one off a Chopper that he thinks should be the same as the Mastiff. Said that if it works, he will make me one cause the one off the chopper wasn't in the best of shape. But I appreciate you offering to help me out.
04 would have been a Kerker. The one you got have the supertrapp logo?
Mastiff Rider64
Yes it does have the Supertrapp logo on it, but looks just like the Kerker 2 into 1 that came on the 04 models. Only real difference I've seen is the baffles between the 2. The Kerker had a cone shaped baffle with a chrome tip that stuck out the end of the pipe a little and the Supertrapp has the disk in it. Which I've never fooled with and have to study up on some. My thinking is that I can turn the megaphone to where the mount that the bolts go in toward the bike and the 04 Mastiff/Chopper bracket should line up with the mount on the pipe. I know the 08 Mutt bracket went under the pipe like in the picture above of the 08 Mutt, but without the original 08 Mutt bracket I'm just trying to make something work. lol
Do you still have your original supertrapp bracket from the original pipes on your mastiff? I bet that would get you close
Mastiff Rider64
No, the factory pipes or bracket was never returned to me when I had them changed out at MB bike week years ago. Funny thing is I went from the factory exhaust to a kerker 2 into 1. Now here it is close to 15 years later and I may end up with the same exhaust I ran for years before switching to the FSD's back close to 2012 or so. lol
Bell bottoms are back in style! Haha what goes around comes around!
No just some times, change is needed. 10 more years you'll go back to the FSD haha.
knothead
Second Chance Customs
This is a 04 mastiff bracket....frame mount holes are 2" centers....the exhaust holes are 3" centers...I dont know if they are the same as the chopper....i just know the ridgeback has a wider frame pattern for the bolts which is 2 7/8...i dont know if this will work for you or not...if you need to know more measurements just let me know....
EDIT : Just got off the phone with Shannon and we discuseed the measurments....He is going to fix you up
john sachs
You should be able to have someone that can weld make or modify your bracket.
John
Mastiff Rider64
John
Well the problem is I don't have one, The Mastiff has a set of FSD's on it free floating. And the Bagger now has a set of the Ambush pipes on it, also at the moment free floating. But I'm seriously thinking I want this pipe on the Mastiff because the motor is built on it and this is known as a performance pipe.
