alhall88
UAW
Well briefly, after you remove the thunderheart module and the stock ignition. You basically install the new ignition just like the old one, run the harness up under the seat drop off 2 of the wires then feed the remaining 3 through the backbone to the coils. The 2 wires under the seat are one for the voes which you just tape off, and the other will be for the tach. The last 3 wires will be for the backbone. Once wired all you have to do is static time the motor to get it running then either take it in for a good tune on a dyno or try it yourself. The hardest part will be getting the motor mount,coils,coil brackets all mounted up.
