Clutch
Ok had my clutch worked on picke the bike up and it ran great. Shifted great and everything. After about 80 miles it was like I had no clutch. I was at a red light and the bike was inching forward. I got on a bypass to head home so I wouldn’t have to use the clutch. When I exited and got to the stop sign the clutch felt normal. What could cause this? Before when I squeezed the clutch it was easy and would barely engage just before touching the handle. Then I ride 5 miles and it’s ok
Reached a high level of heat? So, did you shift a lot in heavy [creeping] traffic?
Notice you rode so no shifting and more cooled the clutch pack. You come to a stop and all is normal because no excess creep in traffic?
Clutch inching forward = Excess heat.
Normal at stop sign = A clutch does not self repair itself.
Until the OP's info changes, this is the [heat] scenario and the guess at it.
Would the heat make it feel like it had no clutch when you squeeze the clutch handle? It felt like the cable was to loose is the best way I can explain it
Jersey Big Mike
100K mile club
Pull the inspection cover check for fluid level, if ok, I'd drain and pull the cover off and check the clutch hub nut.
Also check the routing of the clutch cable and see if its got any places its getting hung up.
Perfectly explained.
When racing, the lever play goes loose, so yes... heat related is the guess by using the empirical deduction.
Like I said, the clutch center bolt does not loosen up and retighten itself back up.
Mike, he took a ride to cool the engine off, then at the stop the clutch center bolt tightened up. Not trying to be a dick. Read the OP's description... what little is said. Now, ask yourself again if it's a loose center nut... just happened once.
See if you agree.
1. Plates grow out ~ still touch ~ pushes pressure plate out ~ rod floats away from p/p ~ lever play excessive.
2. Lever is pulled in ~ plates still [ever so] touch ~ rod is taken up ~ creep occurs ~ throw is all she wrote with expanded plates ~ rolling to that rear bumper.
Signed,
NOLTT
Jersey Big Mike
100K mile club
See if you agree.
Signed,
NOLTT
Agreed, the biggest reason for the clutch nut reference is the number of times I've heard/seen the clutch worked on by a Harley guy and the torque being only 80ft/lbs vs the 150ft/lbs that the BDM requires. I should have made that clear.
Just had a clutch put in it last week. Was riding today went about 50 miles and the clutch handle just freely hoes to the grip with no resistance. I can feel the cable moving all the way to the end so it isn’t broken. It did this once before. The nut that holds the cable came loose. It’s just getting old Getting it fixed riding 100 miles breaking down getting it fixed
Just had a clutch put in it last week. Was riding today went about 50 miles and the clutch handle just freely hoes to the grip with no resistance. I can feel the cable moving all the way to the end so it isn’t broken. It did this once before. The nut that holds the cable came loose. It’s just getting old Getting it fixed riding 100 miles breaking down getting it fixed. Plus I just had to handle rebuilt
Where I said, "Read the OP's description... what little is said..." and now I have to add to the list... A cable nut coming loose and tightening up is not about to return the lever back to normal.
Where you said: "When I exited and got to the stop sign the clutch felt normal."
Kind of see how the quag goes mire? Kind of see how I covered my ass on this one on what little info shoots in?
So now we add more to the short story at the beginning, get it? Oh, someone was in the clutch assembly last week. At this point, hot ambient does not apply. This is more called a 'Come-Back" on the wrenching end. Apply the heat to the customer complaint.
Signed,
Now I'm being a Dick
With these vibration filled monsters, Loctite is your friend.
Mikeinjersey
Time to get a new mechanic! How about giving it a shot yourself? Start with a simple clutch adj . These adj are for right side drive bikes. From your description it sounds like you may have a bind in the system. If after the adj you still have a problem pull the primary cover and look for smooth operation and restoring of the clutch discs . A sticking or bent push rod, failing throw out bearing, a binding ball & ramp are among several causes for wacky operation of the clutch.
Marky-Marc Clutch rod adj.
next time you open the clutch adjustment on the right side, and attempt to adjust the pushrod, go ahead and pull the pushrod out and have a look at the pointy end to see if is worn down.. should be shiny. the rod itself is case hardened, if it starts wearing it will go quickly.
