41bigdawg
Let the Big Dawg eat !
Bottom right of 2nd pic ShannonCan't see it, that's the ignition module.
Sent from my SAMSUNG-SM-N910A using Tapatalk
which wires? Probably other guy has same issue.Got it figure out ,
The wires were reversed ..
I am a dumbass...
Bright side I now have 3 daymaker headlights
I had the wires messed up from docs headlight harness, I had a pigtail from an old headlight that I pulled out of my spare parts drawer and used it to switch the wires around. As soon as I pulled it out and looked at my setup , I recognized that the wires were not installed properly. Switched them around and sure enough that thing lights up my garage.which wires? Probably other guy has same issue.
Well you got enough to last you 20 years now.
It was weird they didnt work for you I've had them in all units available personally no joke. Well except original ehc. Docs, WP, Rip and axles
Glad the problem is solved!I had the wires messed up from docs headlight harness, I had a pigtail from an old headlight that I pulled out of my spare parts drawer and used it to switch the wires around. As soon as I pulled it out and looked at my setup , I recognized that the wires were not installed properly. Switched them around and sure enough that thing lights up my garage.
The headlight was a little loose in the adjure bucket, I used electrical tape around the black trim of the headlight and put about 3 layers around it, the headlight is fully seated and does not move inside the bucket.
Thanks and the light is awesome especially for the price..
Check your wires coming from the headlight harness, I found that I had them installed into the plug wrong and that was my issue. Yellow wire is on top, white wire on the left from the front and ground is on the rightMy replacement is not due until tomorrow . Probably wont get to until Monday and if it doesnt work I guess I will buy the one LED Bulb that shovelheadkicker has for $40
Yea, he and I can see the fuse. He'll have to take the side cover off to see the EHC.Bottom right of 2nd pic Shannon
Yea, those bolts you see just inside the frame. 7/16'' socket.Do the side covers have to come off?
I did not, ShitGlad the problem is solved!
Loose? You kept the wave ring in the adjure, right? Mine is tight as hell in the adjure.
Which side should the EHC be on?Yea, he and I can see the fuse. He'll have to take the side cover off to see the EHC.
Right side.Which side should the EHC be on?
Do you have the manufacturer's model number? I'm trying to make sure I order the correct one for my 08 pitbull.
In my wreck when the lady hit me, the entire headlight mount broke and the can was hanging by the wires the LED made its way into the 06 I rebuilt still works and not a scratch on it....seems like if you got problems it's quick otherwise these things last and for the price even replacing it every few years is worth it. Although I've had these for for 3-4 years and about 10k on each and no issues.I can share, I have had a couple of these. My first had discoloring and condensation in it. I posted earlier in this thread. They replaced it a couple years ago and so far so good.
Then first time out this year my set screw came out and my light and all the retaining rings fell out.
A guy driving behind me chased us down because he saw the light fly off. He had retrieved it for me thankfully. I threw it in my bag and came home.
The next day I pulled it out and there wasn’t a scratch on it, at least the face, and it worked perfectly.
Donna hooked me up with new rings and back in business.
I saw one too many Daymakers go by on the road, and I jumped in the water too. I should have done this sooner... LOLMy Adjure is holding up well......but you guys sure make me which I had one![]()
hi I have been reading all the responses regarding the daymaker headlight and I clicked on the Amazon link in the string. I am curious, the link provides 4 options, two of which have a halo. Will any of those 4 options on the link work in my 06 K9?So Eric (Th3infamaous1) suggested this headlight to me a few months back.. finally got around to ordering it and not only does it look better just sitting in place, it seems to be quite a bit brighter and kinda gives you a straight solid flat line beam to work with.. way to go and cheers to Eric!
Old thread those halo are new additions, originally it was just the two standard ones.hi I have been reading all the responses regarding the daymaker headlight and I clicked on the Amazon link in the string. I am curious, the link provides 4 options, two of which have a halo. Will any of those 4 options on the link work in my 06 K9?
Man Eric — I thought you were MY personal geniusOld thread those halo are new additions, originally it was just the two standard ones.
All 4 would work except Halo ring wouldnt work without a some rewire work. Low beam is always on, so really no value in a Halo ring other than looks, you would have to splice it into the low beam or high beam depending on when you wanted it on.
