Brakelights
Lumi Ints
Hi members, any ideas about missing brakelights ( Mastiff 2008 ) Just one day I noticed that both brakelights do not work any more. All other lights, horn and etc. are ok. It does not matter which brake I try, front or rear, nothing happens. All thoughts are welcome. Regards, Indrek
heybaylor
do the rear turn signals work ?
they use the same element as the brake lights.
if not then check the bulbs.
if ok ,then break out the ohm meter.
start simple , sometimes the obvious makes the difficult go away
Mikeinjersey
Check out this diagram for help finding your problem. If you have no lights to either rear turn signal (running lights or emergency flashers) it is likely the harness that feeds both is broken. Under your seat is a good place to start looking . Look at the top right side of this Wire Diagram and you will see how the R and L turn signals are connected.
Check your EHC for fault indicator lights for clues to the problem.
Lumi Ints
turn signals work, just brake lights missing
Lumi Ints
Thanks!
