Gas Cap
HD-103
Is there some other palce to by a good replacement cap to fit the stock paint saver ring?? I have a 2004 chopper and cant get the cap out by hand at times. Sucks!!!
Thanks
Richard R
KEY word paint saver !!!!!!!!!!!!! keep it stock !!!!!!!!!!!!!!
If it is better !! ok !!! change it !! If it works !! DO NOT MAKE A NEW WHEEL !!!!
churcott69
I have a 2004 pitbull and want to remoze paint savors. are they standard thread or do they unscrew the same direction of the cap
mleach72
Ok, got the cap off, now what? I need a magic wand or a stick of dynamite to get the rest out
Now you have to get the paint saver out. If you are real careful, you may be able to turn it with a flat screwdriver and hammer, or order the tool from bigdogpartskingpin.com
Stacybeanr
ok c
ok, it came out pretty easy with channel locks but now tank needs emptied and cleaned out since epoxy just crumbled. I'm sure some fell down in tank. Now that the paint saver is out most gas caps will fit right?
mleach72
ok c
Any harley style gas cap will fit, but you will have to do the same thing to the left side if you want the caps to match. The other option is to order a new cap and paint saver from bigdogpartskingpin.
