Does the compession release need removed to access this port ?Here's another area to be checked. I find it on Twin Cam heads also. The pressure relief port in the exhaust port gets plugged up frequently with oil, and carbon. When that happens, the relief pressure can't exit. I unclog with a steel rod, air pressure, and brake cleaner.
John
YES. To clarify. The release needs to be removed so the relief port can get cleaned properly. If you don't remove it, the rod you're using will pack that area, and become a dead end when it hits the release.Does the compession release need removed to access this port ?
Thanks
Thanks very much.YES. To clarify. The release needs to be removed so the relief port can get cleaned properly. If you don't remove it, the rod you're using will pack that area, and become a dead end when it hits the release.
John
