S&S 107 spark plug
Big dog papa
Is there a better spark plug for the ss 107 motor than what the manual calls for?
I had a good laugh going thru that old thread. You guys crack me up... 'pipe bomb'...
Are you saying; same heat range, but a different brand? Or are you saying a different heat range? If you buy a new vehicle, and no matter the state, book calls for the same plug. The heat range did not change from state to state. It means, that spec was covering all the ambient changes and came away with the overall performing plug.
I doubt HD has their own plug business, but uses a jobber like Champion to go over the bike with them and come away with a heat range that won't melt the engine, basically. Short of a radio frequency plug, if you looked at the porcelain bodies, they probably are the same plug heat wise.
Too little pour = Less Heat Made ~ Carbon build on the porcelain.
Book Spec = OL Performance ~ Clean white/tan tips.
Too much pour = More Heat Retained ~ Knocking on the door of the kinetic meets spark to arc gray matter [dots of aluminum] on the porcelain, and a tiny crater where the plug meets the dome of the piston.
I would stay stock or the field test that JJ came away with.
Big dog papa
Here's a look at my plugs. To me they don't look hot enough or running too rich. The darker one is the back cylinder16162617823896378859532439927934.jpg
Left plug ~ it's shinny wet. That means ring or guide failure. Check compression on both cylinders and match comp's.
Right plug ~ it's a little dryer, but on the verge of going oil foul. Plugs should have a white/light tan porcelain if well jetted and high in compression.
Huston, we have a problem.
By the looks of the outside, I'd say they have been in there a while. Plugs are cheap, change them each spring. You can do a compression test if you want, but I'd change them out, ride it a few miles, pull and reaccess the situation.
Big dog papa
Thanks for the info. I bought a new set today .I'll take your advice. Thx again. :chopper:
john sachs
I've done a bit of A-B dyno testing with quite a few different brands of spark plugs. NEVER any difference after a few pulls, other than a liter wallet. Occasionally a slight timing change will take the plug that may have been a touch low, and bring it back even with the others. Ain't NO magic in the plugs if the gaps, timing, and fuel mixture is correct.
John
Now wires are a different subject.
Big dog papa
John
Good info.. Thx John.
DynoDave
John
What are the magic plug wires?????
