No spark new battery
Rottweiler
Yes I would check all the wires on the battery. When you first turn on the key the ehc does a self check. You said it lit the ignition fault light. You also said you don't have 12vdc at the module. We need to find out why. You never said how fast the bike is turning over.
Sent from my Life One X3 using Tapatalk
LittleMike
i ran the test again, i get 10.5 and the bike spins over good, 500cca battery
Rottweiler
Ok
I would disconnect the negative from the battery. Then take the plug off of the ehc. Clean all the pins and look for any damage. You can check the print for which pins feed the ignition. 10.5 volts may not be enough?
LittleMike
The cam sensor failed all the continutity tests so I just ordered a new one today. I will post as soon as that is installed. It has to be that according to the tests.
And special thanks to these guys for the help!
Mr.Wright and Rottweiler
LittleMike
I searched for an answer to this problem on Big Dog forums exclusively and I have found a lot of threads that are just deadends. The original poster never puts his fix in to end the thread.
My issue turned out to be so simple. I had a loose pin/wire in the cam sensor connector. Runs good and the thunderheart was beating like a drum.
Thanks Mr. Wright. I bugged the hell out of him with emails, texts and phone calls.
I hope I can pass it forward someday and help some other dumbshit like me.
LittleMike
Ok
Thanks!
It turned out be a loose pin/wire. Easy fix but an embarrassing one.
Rottweiler
Glad to hear it was a easy fix. That is why we are here. Gotta keep these bikes on the road where they belong. Also they put that smile on your face quicker at 55 mph.
