NEW 9 plate EZ pull ball and ramp
rpols7
like the title says I have 6 sets new never used, 200.00 a set with free shipping to the lower 48ramp.jpg
rpols7
These are from Baker and were for 08 and newer with the 9 plate clutch. From what I read on the forum guys have installed them in the 05-07 with the 12 plate clutch because the stack height is the same. The 9 plate has thicker steel plates and less clutch plates. Do your research and let me know because I have never actually installed in anything older then an 08. Barnes list his for 05 - up with saying he change the material they are made of for grease retention. Personally I have never heard of a set wearing out. Let me know.
Yes, I have install them in a 12 disk clutch. BUT, you really need to measure your clutch stack to make sure it is thicker than 1.970''. If your old clutch is worn any more than that, you will have a hard time adjusting it, so you can find neutral. Having to jack the throttle to find neutral, is not a proper adjustment.
Pops
Thanks for your reply !!
