tach works off the ignition module
Green is tach on your new unit it will be connected to the green wire going into the Thunder Heart box.
_________________________________________________
Green to Green - (Going into Thunder Heart Box)
Blue to Yellow (Leaving Thunder Heart Box) - Front Cylinder
Pink to Blue (Leaving Thunder Heart Box) - Rear Cylinder
Red coming into the box your best bet is to to crimp it to both White on the Ultima Ignition & Red on the wire leaving the thunder Heart box to power your coil & ignition module when you turn on the key & hit the run button to keep it same as stock.
Violet you won't use just cut and heat shrink wherever.
I see the green (tach) wire out of the ignition module on the wire diagram , I'm just trying to get this all figured out before I go splice and wires and f****** something up, this is my idea of the green wire to this green wire but didn't know if the ignition module generated this signal or if we could patch it in after the ignition module , or if it was the same being now it's off the cam instead of the crank position sensor
