Hello all. Just joined the group on the recommendation from a fella on the FB forum. I just bought an 04 Ridgeback from an auction super cheap but without any clue what's wrong with it. So, I get it in my hobby shop and put a good battery in it. Turn the key and the ehc lit up. That's it. No lights or gauge. The start but is also non-functional. I found a wiring diagram and took the switch off. I tested for voltage from black to red and black to green. 8.5VDC. I would expect it to be 12vdc indicating a faulty ehc but being as it's all computer controlled it doesn't necessarily have to be. I did get another set of hands and we did our best to test the switch finding no continuity. I found a pin diagram for the ehc and tested it directly ruling out a wiring problem and got 8.5 volts at the corresponding pins. Does anyone know what the correct voltage is at that 6 pin connector? Any help would be very much appreciated!
