CCA is so misrepresented by "off name" brands it is astonishing.I need a new battery for my 2006 Mastiff. I searched and didn't find anything. What would be the best battery ? Has a brand new one 450cca and its not enough.
check your compression releases and nmake sure that battery is fully charged first -- does it try at all?Its a WPX20L-LS from amazon from Battery Sharks. Brand new and just don't have enough ass to turn it over. Guess I will order a deka 310 cca.
Yes just barley spins over.check your compression releases and nmake sure that battery is fully charged first -- does it try at all?
I actually need a new battery too. Thx for the info!CCA is so misrepresented by "off name" brands it is astonishing.
Get a real name Brand -- get a DEKA -- 310CCA
You can order online or get from a harley dealer.
Personally I've been using the Duracell from Batteries Plus for a couple of years with great results and great service
https://www.batteriesplus.com/battery/motorcycle/big-dog/mastiff/1750cc/2006#finder-box-top - Order online and there is a code to get $10 off.
If you also sign up for Rakuten, you can get another 3% off on the battery and a bunch of other places as well. https://www.ebates.com/r/BIGMIK880?eeid=28187
I've gotten about 25 back in the past year from them!
Damn sorry to hear about that. Sounds like it might be something other than the battery. Your sure the compression release are working correctly? This would drain your new battery real fast if not.Yes just barley spins over.
I hace a 2006 Mastiff and have been using the TR- B1500 racing Battery, has 465 CC power and I have not had any issues. They are Pricey but they last a long time. I keep mine on a Battery Tender most of the time so it lasts about 5 Years and it s the right height, width and length Check it outI need a new battery for my 2006 Mastiff. I searched and didn't find anything. What would be the best battery ? Has a brand new one 450cca and its not enough.
The NEW Antigravity ATX-20-HD battery is a High Power, lightweight lithium replacement for the popular YTX-20 size Lead / Acid battery. This is HEAVY DUTY version, designed with significant Power and Amp-Hour Capacity in this popular case size.
You can, but disconnect it quickly after it starts.Got question ? Is it safe to use one of those lithium pocket sized jump start packs on a 04 Big Dog ? I saw a comment never jump start off a running vehicle.
Thanks,
Hope this is not to far off topic.
ThanksYou can, but disconnect it quickly after it starts.
Just took this one out of the box that I ordered that took 3 weeks to get here with the postal delays. Why I recommend Amazon, they are the cheapest around ($100 shipped to your door) and they move more batteries than anyone. 12/20 manufacture date and 693.5 CA out of the box, usually I see it around 550-560 so I know this one is really fresh and the sticker isn't a lie.There's a million threads on batteries, just had one the other day.
No speedo, no lights, no start.
Hey guys, it's been a bit since I've been around but finally started getting a little time to ride again. Haven't had issues until the other day. Roll my bike out to take my daughter for a little spin. Started right up with no issues. Had a nice little ride with issues. Stopped for a little...www.bigdogbiker.com
Either way, general consensus is the Deka ETX20L, Amazon is the cheapest place to get it and it's usually not more than a month or two from manufacture date. I wouldn't buy batteries from a local store, just because who knows how many months or years it's been on the shelf.
DEKA ETX20L Amazon Link
Tomioka Racing TR-B1500 Performance Lightweight Battery
Carlos![]()
Must be a "Lightning Start" battery. I've had good & bad luck with these batteries. At first I thought Wow, 450 cca. I had on last on my 03 Pit Bull 107 S&S without compression releases for 5 years. Then I've had others ( I own 5 bikes) that barely made it a year (11 months). Although in that case it was replaced including shipping for free. I now have a Deka installed in one bike, and will replace all the others with Deka when they take a dump. Great batteries, and don't let the lower CCA scare you off, they have plenty of juice.Its a WPX20L-LS from amazon from Battery Sharks. Brand new and just don't have enough ass to turn it over. Guess I will order a deka 310 cca.
