But did you check with an OHM meter is the low beam filament is ok in the lamp.Disconnected my headlamp the high beam on the Speedometer keeps blinking even though headlamp is disconnectedWhen I activate hazard lights headlamp shuts off bike won’t start on either occasion I get completely nothing going to check battery now will get back to you
I know on my '07 bulldog I want to start it today and even though I had it on a tender the battery still went weaker than it was needed to start the bike, it cranked over and then immediately my hazards come on and it's always been like that for the last five six years that I've had the bike if the battery ever gets a little weak my hazards come on or put the bike on a charger it just now fully charged and went out and it cranked right up not sure if this is going to help but it's probably your battery check and make sure everything is tight.
Sent from my Pixel 3 XL using Tapatalk
I agree with Mike, but what is causing it, is probably a shorted cell in the battery. It may read 12.8 voltage, but it needs to be load tested.
Replace it with a Deka battery. You can get it on Amazon or pick it up at a Harley shop.
It was the headlight bulb I changed it out highbeam and low beam working fine bike still won’t start sending a video of the lights on the EHCBut did you check with an OHM meter is the low beam filament is ok in the lamp.
The EHC will when not enopugh load detected on low beam auto switch to high beam and I have seen it bounce back and forth since it reads the switch and goes OH, no I should be low beam not high, then says, ah low beam looks bad (loop) It's a missing error trap in the EHC code. Should only do that once - low beam inadequate current go to high beam -- it should not reset by itself till switch thrown or power cycle. An easy miss in the code for the microcontroller in the EHC.
When I turn the key blinking green instead of yellow light what you see in the picture I hold the run button for two three seconds I hit the stop button and then the red light appears which is in the second picture stays on for about 10/ 15 seconds and then shuts off and the yellow with the blinking green just stay onIt was the headlight bulb I changed it out highbeam and low beam working fine bike still won’t start sending a video of the lights on the EHC
I have the same thing happen with my 07, if doesn't have enough cca from the battery the Hazzard lights go off. Solution was a new Daka batteryI turn the ignition key on my highbeam keeps blinking on and off with no way to stop it and I get no other functions or controls at all I have a 2008 big dog pitbull any idea
I change the PCB switches and the bike started perfectly I just have one question on the start board there’s a wire with like a metal solenoid that goes into your housing how far deep into the housing is that supposed to go and does that control your brake light when you pull the front brakeI have the same thing happen with my 07, if doesn't have enough cca from the battery the Hazzard lights go off. Solution was a new Daka battery
Sent from my SM-G973U using Tapatalk
I would also like to say thanks for all the help from everyoneI change the PCB switches and the bike started perfectly I just have one question on the start board there’s a wire with like a metal solenoid that goes into your housing how far deep into the housing is that supposed to go and does that control your brake light when you pull the front brake
