Mike manson
That setup work on ridgebacksThe setup I posted will cost $55
OkYes led bulbs come in pairs if ya get another member to split with ya it's $55 each
"I ride at night sometimes, and LED made a world of difference. "Now I know others can see me too.
I don’t ride at night either. So I decided to just leave well enough alone. Lol. Quite happy with the stock light.I don't like the look of the Daymaker either. I have the diamond cut light with this LED. It is bright and I like the look but I don't ride at night so I can't tell you what it's like at night. https://www.amazon.com/gp/product/B01EWH8YZE/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
Do you have a part number?Before, PIAA Extreme White
After, LED Lumens: 2300LM for Low beam 4800LM for High Beam (Pics are in Low Beam)
Check your plug in they melt if they are the plastic one.i purchased a Sunpie Daymaker for my 2007 Big Dog Bulldog. The brightness and the pattern of the light is great. I was wondering if anyone has the problem of the bulb flickering at idle and riding? This happens on low beam as well as high beam. Does anyone know what to do to fix this or should I try another make of bulb? Any suggestions would be appreciated as I really like the Daymaker and would like to keep it.
At home yes... I am in Iraq at the moment. Sorry.Do you have a part number?
I’ve had two of them in a row fail. I noticed that the light was apparently jittering when I pulled up behind a pickup in traffic at a stoplight. In both cases the little glass discs (diffusers) on each side of the headlight came glued and were vibrating. Oh well, only $50 apiece….no more Sunpies for me. I sent an email of complaint to the most recent vendor, but no answer.i purchased a Sunpie Daymaker for my 2007 Big Dog Bulldog. The brightness and the pattern of the light is great. I was wondering if anyone has the problem of the bulb flickering at idle and riding? This happens on low beam as well as high beam. Does anyone know what to do to fix this or should I try another make of bulb? Any suggestions would be appreciated as I really like the Daymaker and would like to keep it.
Hey Brother I have a Iron horse and the housing so I bought a LED light cause I couldn't see shit at night, so when I got the light it didn't work, same housing but I've been told to get a resister, cause of it's a different light.. Has anyone had to get that for the difference?Here’s my sunpie daymaker. Not a bad piece compared to stock. I’m thinking about trying the Lamonster garage led bulb in stock housing.
View attachment 54971 View attachment 54970
The only time I have seen a bike need a resistor is when the load was not enough and the headlight switches to high beam automatically thinking the low beam is out since it's not drawing enough amps.Hey Brother I have a Iron horse and the housing so I bought a LED light cause I couldn't see shit at night, so when I got the light it didn't work, same housing but I've been told to get a resister, cause of it's a different light.. Has anyone had to get that for the difference?
Will the Wolf work with a 2007 Big Dog? I read they only work on 2009 and up.Here's that bulb from DOC's, low beam and high beamthis is about 100' from the garage and this is using the Wolf headlight housing.
View attachment 34042 View attachment 34043
IHey guys, trying to narrow down my search as to what headlight setup i was going to go with on my 03 chopper. Originally i was going to go with the diamond cut headlight and LED bulb from wildsteedworx. Then i started researching the other LED setups that are out there now and im torn. Im starting to kind of like the daymaker setup that harley runs now, but I dont know if im actually going to like the look of it on my bike. So what are you guys running for headlight setups? If you have pics installed i think that would be helpful. Plus i know we have a lot of issues with the electrical system so if theres anything else i should be aware of before pulling the trigger that would be helpful too!!
Thanks guys
I just went with Custom Dynamics adaptive headlight. Cool as hell. You can see the extra lighting when leaning. Theres a side by side from and back. It fits perfectly.Hey guys, trying to narrow down my search as to what headlight setup i was going to go with on my 03 chopper. Originally i was going to go with the diamond cut headlight and LED bulb from wildsteedworx. Then i started researching the other LED setups that are out there now and im torn. Im starting to kind of like the daymaker setup that harley runs now, but I dont know if im actually going to like the look of it on my bike. So what are you guys running for headlight setups? If you have pics installed i think that would be helpful. Plus i know we have a lot of issues with the electrical system so if theres anything else i should be aware of before pulling the trigger that would be helpful too!!
Thanks guys
