thank youOn the end of the throttle cable ball, that is what holds the cable in the slot of the grip.
Sent from my SM-N975U using Tapatalk
well keep them in case i need one!I have found several of those laying on the floor around the shop—always AFTER I purchased replacements and reassembled the throttle cables.....haha
I just bought a few spares to keep handy.
The job ain't finished until the left over parts are picked up off the floor...lmaoFinish the story. I set it on the running board so it wouldn't get lost, before I put it back together. Thanks for picking it up and putting it in a bag.
I don't think it matters, but I always put the slotted end in the saddle first. It sort of blocks off the slot and helps keep the cable from popping out as you slide it through the saddle.Hey guys I need a little help with the Ferrules. I am replacing my right hand control pcb . When Putting it back together and installing the ferrules like the one above . Can you tell me it the end of the ferrule you see in the pic above is supposed to be facing outward towards the grip or inward, Or does it matter.
Thanks for any help.
