Marky-Marc
Just an update.
Moved to florida with all my bikes.
As you know, my wire plus blew up and I replaced it with OEM harness and AXEL EHC. Kaptin and I rewired my bike.
a. I am STILL a TRUE believer in AXEL’s EHC
b. Please do keep supporting the KAPTIN at wildsteedworx.com and Derek, Erik and Donna.
Here’s what happened:
All of a sudden, my bike started shutting down when warm, at any RPM…all I had to do was hit RUN and pop clutch and it would restart….then, a few miles later, same thing…when it shut down though, it would RESET my trip ODOMETER……every single time…..
SO, since I have EXTRA parts, here’s what I replaced:
Ignition module
PCB boards
Speed Sensor
REPlaced COIL
TACH ring
checked headlight…..
pulled tank and checked all wiring…..all grounds good….
No matter what I did, or replaced, bike kept shutting down after warmed up…..so, against all odds, because AXEL’s EHC is AWESOME…….I decided to put pull AXEL’s EHC and put my OEM Big Dog EHC back in…hasn’t shut down in 600 miles plus…
so then….yes it goes on…because I LOVE AXEL’s EHC, I put that same AXEL EHC in my mastiff (removing the OEM EHC) and went for a ride….just to test my theory….and it started shutting down my Mastiff when warmed up…..
Goes to show, AXEL’s EHC is AWESOME, but manufacturing SUCKS! Not his issue, but something just isn’t right….
Peace….
MM.
Ignition module
PCB boards
Speed Sensor
REPlaced COIL
TACH ring
Peace….
MM.
