knothead
Yes LED uses lessChecked all connections and ordered a solenoid rebuild to start. Might get a new battery also. Funny this all started when I put an LED headlight bulb in, they do us less voltage don't they?
Have your battery load tested today. If it needs one get it.Checked all connections and ordered a solenoid rebuild to start. Might get a new battery also. Funny this all started when I put an LED headlight bulb in, they do us less voltage don't they?
What parts of the charging system?Like I told you before. Replace your charging system.
Sent from my Pixel 3 using Tapatalk
DK Dennis Kirk?Solenoid rebuild did nothing to help, maybe made it worst now it wont start at all. The rebuild kit form DK is a piece of shit, used three parts out of it used the stock parts for the rest. Thinking I should order a battery and a starter. Any thoughts?
www.bigdogpartskingpin.com
I did just like you said put a ground tab on the starter bolt. Used the battery out of my truck, with the Positive lead on the solenoid lug where the battery positive bolts to and ground on to the lug I got nothing. When I switch the positive lead to the lug on the starter the starter spins but of course not engage to turn the engine over. So it sounds like a solenoid problem? The rebuild kit done nothing to help.Car battery to jumpers on bike battery. Car off, just borrowing a larger storage of 12v. So that's jumper on large red wire down to the starter motor, past relay or at the lug of the relay with the cable to bike's starter motor.
Jumpers are on car, you now hold the ground of the jumper. This is going to spike and arc, so better you find a hidden ground where arc is for sure going to patina when that starter motor is about to be benched tested in the bike. I mean this is going to melt the lead on the ground side of the battery you go there. That's why you want to bolt a tang? Drill it and bolt to ground. The flat steel gets the sacrificial arc. And the least arc is the faster, most sable stab, and don't flinch, you won't get shocked.
Hold it there... if it keeps turning over the engine, it's not the starter as a variable to a start issue.
Inside the solenoid where that green wire connects, there are small bare looking wires that go back into the solenoid. Those little wires are what energize the coil to magnetically pull the “plunger” back against the spring, and make the copper disc touch the two big copper lugs. Anyhow,,, my starter somehow managed to break one of those little wires and the starter to not work . A very smart man, (MrWright) ,told me to solder the broken wire back together, and guess what! On the road again! And yes , I am still indebted to Shannon! He has saved my butt several times because that’s just the way he is, A truly good person and friend!I did just like you said put a ground tab on the starter bolt. Used the battery out of my truck, with the Positive lead on the solenoid lug where the battery positive bolts to and ground on to the lug I got nothing. When I switch the positive lead to the lug on the starter the starter spins but of course not engage to turn the engine over. So it sounds like a solenoid problem? The rebuild kit done nothing to help.
Thanks, I will have a look at that.Inside the solenoid where that green wire connects, there are small bare looking wires that go back into the solenoid. Those little wires are what energize the coil to magnetically pull the “plunger” back against the spring, and make the copper disc touch the two big copper lugs. Anyhow,,, my starter somehow managed to break one of those little wires and the starter to not work . A very smart man, (MrWright) ,told me to solder the broken wire back together, and guess what! On the road again! And yes , I am still indebted to Shannon! He has saved my butt several times because that’s just the way he is, A truly good person and friend!
Wires in the solenoid all look good. It appears I have a bad solenoid, thinking I need to replace the starter.Thanks, I will have a look at that.
From your overall description I would guess your starter gears are broken. Good news there inexpensive and easy to replace. If you also have a bad solenoid just get a slam button .Am I thinking correctly? If I am putting more than 14 volts from my truck battery directly to the starter, not to the solenoid and the starter spins but is not engaging the starter gear then my gear or jackshaft is broken.
