This look ok?
Tubolove
Speed sensor working speedometer is not though it does sweep all the way to 140 when the bike is turned on and again when started.
Can’t seem to find a wiring diagram for a 2002 big dog. Does this look OK? There’s an extra plug should be plugged into something?E86D4C9C-8F2D-4E7C-883F-C0BE45428A52.jpeg392F9F09-3B6F-4395-96D8-946565710043.jpeg
Jersey Big Mike
100K mile club
Have you tried recalibrating the speedo and seeing what happens.
The 2002 manual in the drop box connection does tell you how to calibrate .
Is that connector insert well into the board (hard to tell from pic.
Tubolove
OK I got out my handy-dandy volt meter and it looks like there’s a break in the continuity on the green wire between the speedometer and the speed sensor. When I roll the bike the volta go up and down at the connector near the battery and then I trace the wire up under the tank and into the back of the speedometer the green wire has no continuity or voltage jumping up and down when I move the bike.
Tubolove
I’m thinking that extra plug after looking at it is pre-wiring for maybe a tach. It uses the ground and 12v+ From the speedo and the yellow wire has continuity with a yellow wire that’s near my battery/ehc that is not hooked up to anything.
I was gonna say the same. More than likely a tach plug.
