willywill4765
I had like 14.04 to 14.11 and it stayed there pretty steadyJust read the end how do you check the vent on the gas cap
Sent from my Pixel 3 XL using Tapatalk
Willy,Does anybody know what is the correct way to check what the voltage regulator is sending to the battery do I just put my voltmeter on the 40 amp breaker and test it that way or is there a better way
Sorry tree man, you're right on everything except for the fact that the cap does need to be vented or it will vapor lock the tank. The only caps that are not vented is the left one on the dual tanks.Some gas caps are vented and some are not vented. My gas cap on the underside had a small white colored octogen shape piece of plastic. I unscrewed it, left it off and put the gas cap back on the tank. Just go out and ride for about the same time you did before and hopefully everything goes okay. When filling your tank don't fill it all the way. If this works you could try a non vented gas cap or just never fill the tank all the way. I never fill mine all the way so I don't take a chance of any leaking on my tank. Good Luck my friend.
Perfect. Remember, highly charged, 14.1 say. Needs a charge, but you're riding it at 14.4+, it's sending in what the battery calls for is a balance back to 14.1 say.I had like 14.04 to 14.11 and it stayed there pretty steady
If your cap had the white insert, it is a vented cap. The white thing was someone's bright idea that didn't work. The new caps don't come with it.Thank you for the information. I will replace my defective fuel cap with a new vented cap.
The little white piece has been a problem in the past. Thats why the new ones don't come with it.Leaving off the white plastic, I blew through the cap and a little air came out one of the three hole on the underside. Is the cap good to use without the little white plastic? Should I buy a new vented cap?
This is what my gas cap looks like on the bike, and underneath the cap pics. Didn't really see anything white is this a new cap or an old capThe little white piece has been a problem in the past. Thats why the new ones don't come with it.
Can you blow through it?This is what my gas cap looks like on the bike, and underneath the cap pics. Didn't really see anything white is this a new cap or an old cap![]()
Yes a little air comes out of one of the holes on the side just seems to be only one hole though that it comes out.Can you blow through it?
I had trouble with the pro tune I had to call S&S they helped me unzip the driver then it workedWhen you plug protein into the little s&s black box I have the software I just can't seem to get it to work is there a certain process, key on, key off, bike started or bike not started.
Do you remember if your bike was running or just the key on, did you plug in the system first from computer to s&s tuner and then turn the key on and then start it what was the processI had trouble with the pro tune I had to call S&S they helped me unzip the driver then it worked
