Snipes4ever
Rode bike yesterday, today went to start it and just get a click when pushing run switch
Load test was 13 12.6Well if it's just clicking, it could be a number of things. Since you rode it all day maybe all that time something came loose? Even though the battery charged up, how does it perform under a load? Since your a "new member" did you just purchase the bike? I would check all connectors first. Have the battery load tested. And report back to us.
That's plenty to turn it over. Hmmn....Load test was 13 12.6
Welcome Snipes, If your battery is reading 12.8vdc or better it's probably OK. After you check that your connections on the batteryRode bike yesterday, today went to start it and just get a click when pushing run switch
Disconnect the battery, then remove the back cover off the starter solenoid. (3 bolts) Remove the plunger, and clean the contacts.Awg
Thanks so much. Yes just purchased bike, first big dog
new to components.
Bike had 8,500 on it mint condition was reading post's
Think it's something stupid.
When I turn the key all lights gauges work hit run and start and
just get Click, nothing ???
I agree with Mr.Wright sounds like it has arch marks all over the contacts and plunger faceDisconnect the battery, then remove the back cover off the starter solenoid. (3 bolts) Remove the plunger, and clean the contacts.
How To: Clean Solenoid Contacts on the starter
Way simple job. Easier off the bike, but you should be able to also do it on the bike if you don't have a belt or lines in the way -- your mileage may vary. OK - first get the starter The important bit is the three screws on the solenoid. Remove them, but remember there is a spring...www.bigdogbiker.com
