blackdogg6164
Hey fellow riders after 4.5 hours i got my new sissy bar and back pad (kinda) installed. Most of my time was with the L bracket bolts holding the fender underneath by the oil filler tube. There is hardly any room for a ratchet OR an allen wrench. They both needed to come off so the fender would slide up and back. I disconnected the connector for the rear lights and after that it was easy to slide out. I used grease to help them with reinstall. I turned the tub upside down, put some WD-40 on all the underside fasteners and removed the struts. I cleaned excess wax from the tub and struts after the disassembly and pulled the strut plates out. I reversed the procedure (with sissy bar) carefully using the new hardware and after reconnecting the rear lights and the evil L bracket I was done. My only head scratcher at this point is how do I secure the back pad? There are no set screws and it doesn't lock in to any grooves. I cannot ride with it until I figure out a way to secure it from falling due to vibration. I'd hate to try to drill set screw holes bit I dont want it stole either. Any ideas?
