I dont but im sure some doI've used Seafoam in my cars and also in my Harley every dozen tankfuls or so.
Never used in on a BDM, do you?
Good point. I have a newer liner in my tanks so no worries here.I would worry about what it would do to the tank liner
Very good to know.FYI: SEAFOAM is made for 2 cycle engines period...... BDM engines are 4 stroke.... seafoam cleans carbon in two stroke engines. Gas and oil mix creates a lot of carbon build up. If you want a cleaner use a nitrogen based cleaner. Tecron uses a nitrogen base. You buy seafoam your spending $ for nothing.no nitrogen in seafoam. Tecron has nitrogen that’s why it cost more. If your storing your bike use sta-Bil. If it’s going to sit use sta-Bill. But I’m telling you forget what grandpa did or told you. DONT PUT SEAFOAM IN ANYTHING EXCEPT A 2 STROKE. PERIOD....
I've used Techron, Seafoam and Marvel Mystery Oil.FYI: SEAFOAM is made for 2 cycle engines period...... BDM engines are 4 stroke.... seafoam cleans carbon in two stroke engines. Gas and oil mix creates a lot of carbon build up. If you want a cleaner use a nitrogen based cleaner. Tecron uses a nitrogen base. You buy seafoam your spending $ for nothing.no nitrogen in seafoam. Tecron has nitrogen that’s why it cost more. If your storing your bike use sta-Bil. If it’s going to sit use sta-Bill. But I’m telling you forget what grandpa did or told you. DONT PUT SEAFOAM IN ANYTHING EXCEPT A 2 STROKE. PERIOD....
I have carb bikes I only put super unleaded and sta-bil. And stabil if I know it going to sit for more than a month. I put it in to save the gaskets in carb. This new crappy fuel will eat your carb up if it sits too long. I put it in my mower and gator, welder, pressure washer, basically anything that I don’t use all the time, some machines don’t have petcocks that being said the ones that do I still shut the pet cock off and let the engine run out of fuel. This crappy ethanol fuel will ruin gaskets. Since boat engine manufacturers started making better boat motors/ 4 stroke engines, the sale of seafoam had all but fallen off market . The marketing people talked with engineers and found out that seafoam will not harm a 4stroke engine or at least couldmy be proven to harm, they decided to change the label to say 2or 4 stroke. Look at an old can and a redesigned can same product different label. Do what you want I’m just giving you the info that I know. If I need to clean a carb I use berrymans B-12. Only for cleaning. Nitrogen based additive would be the one I would use. If you want to clean that 117 engine add 1 part 110 or lower race fuel,2 parts super unleaded. And only every once and a while like a long ride continually on the throttle. I did that with my GSXR 1100 drag bike all the time when I sent my head to be ported they were really impressed with the cleanliness of the engine.Very good to know.
I guess the question now becomes: "is there any reason to put any type of cleaner in your tank?"
(In my case I'm riding at least once per week on the highway ~30 miles)
I never thought about just having one way in and out I have a Three way(lol) intersection. that last 21 miles is auto pilot by now. If people think it works for them and are happy then by all means use it. I have never researched STA-BIL. But I use it. It does work. I have researched SEAFOAM and like I said it’s for 2 stroke engines. I try and buy gas and diesel at the same spots,not always possible,does that mean that gas is bad at other stations? No. I just feel comfortable because I have never had a problem at those spots. Sea foam works great in two stroke engines. I just know that a nitrogen based additive is a hell of a lot better in a 4 stroke. Lucas makes a great diesel injection product. Now as for the transmission crap that they make, I had a diesel with 100k on it went in and bought some injector cleaner saw the transmission additive for high mileage so I said what the hell ive seen their little wheel display and have spun it a few times I said damn must be better. I put it in and no shit the very next day trsnny wouldn’t shift between 4 and fifth without letting off the petal. Two of my solenoids went bad in the tranny. Were thay bad before I put it in? No. Did it cause them to go bad? I don’t know. But they went bad the next day. That tells me a lot. Never agin tranny crap in my tranny. Yes I still use the Lucas injection cleaner. Especially when I’m hauling cows or horses. Just trying to be helpful and informative. Do a little research on SEAFOAM look it up on internet and you-tube. It’s great in boats.Never tried it in the carb'ed bike only the EFI.
Generally when I use it I use less than the spec'ed amount and typically run thru nearly 2 tanks of gas when I am out on a run.
It's a standing joke around here that my first and last 21 miles are almost always the same.
Live on an island and I have to drive to get out of town and hit the bridge to get to the mainland. SO there's goes a 1/4 tank before I even get started really!
I have other ways out, but its traffic hell.I never thought about just having one way in and out I have a Three way(lol) intersection. that last 21 miles is auto pilot by now. If people think it works for them and are happy then by all means use it. I have never researched STA-BIL. But I use it. It does work. I have researched SEAFOAM and like I said it’s for 2 stroke engines. I try and buy gas and diesel at the same spots,not always possible,does that mean that gas is bad at other stations? No. I just feel comfortable because I have never had a problem at those spots. Sea foam works great in two stroke engines. I just know that a nitrogen based additive is a hell of a lot better in a 4 stroke. Lucas makes a great diesel injection product. Now as for the transmission crap that they make, I had a diesel with 100k on it went in and bought some injector cleaner saw the transmission additive for high mileage so I said what the hell ive seen their little wheel display and have spun it a few times I said damn must be better. I put it in and no shit the very next day trsnny wouldn’t shift between 4 and fifth without letting off the petal. Two of my solenoids went bad in the tranny. Were thay bad before I put it in? No. Did it cause them to go bad? I don’t know. But they went bad the next day. That tells me a lot. Never agin tranny crap in my tranny. Yes I still use the Lucas injection cleaner. Especially when I’m hauling cows or horses. Just trying to be helpful and informative. Do a little research on SEAFOAM look it up on internet and you-tube. It’s great in boats.
