Technical
under dog
Have 05 chopper and wonder if any body has fitted a compensating sprocket to there's...? And what sprocket fits and any reson why they (BDM ) didn't put on or any reson I shouldn't put one on. surely it has to easy on drive train with less vibrations .
Yes, there is a thread on this somewhere. I'll see if I can find it later. You will have to change the outer primary cover. The newer bikes had them.
This is the only one I could find. Maybe someone else can remember a thread where it was talked about.
Think that's the only one I remember. To get it to fit you have to machine out the primary cover to allow for the extra space as the compensator is taller than the solid gear. It requires a new front derby cover that actually screws in from the back side of the cover.
Not a hard job necessarily just requires some work and machine time. Won't just bolt on.
