FrankBDPS
What kind of starting issues are you having? What motor do you have? 107,117 or something else. You may install compression releases and still have starting issues. They are not a cure all. Good luck.I am having some trouble starting the bike. Once it starts, it runs great. I figured compression release would help with the starting.
. Test your current battery, check its about 310 CCA, be happy.
compression releases do help, but engine doesn’t need to crank like a sewing machine. I have a 1.7kw high torgue starter on -03, turns the engine over somewhat relaxed speed but starts the engine just great.
