Catfish Daddy
Selling my e carb and intake. From my 05 Bulldog 117. 200 for both
It would run just fine. You would just be leaving some top end hp on the table. It would probably also produce a couple more ft lbs of torque in the low-mid range.So how would a swap from g to e effect my 07 k9?
Just don’t know much about these carbs, and after all the work I have put into the engine I would hate to backpedal ..It would run just fine. You would just be leaving some top end hp on the table. It would probably also produce a couple more ft lbs of torque in the low-mid range.
I'm a big believer in Mikunis, but between the E and G, the G is definitely the better carb for our bikes.Just don’t know much about these carbs, and after all the work I have put into the engine I would hate to backpedal ..
