Bigdaddy08
I have an 08 ridgeback and went for a ride today about an hour after returning saw fluid running down primary from the inspection door at the lower screw is there a gasket that could be bad or something else
Might just be loose screws. Make sure they are tight. If they are, you probably need a new gasket. You can get them from Derek & Donna or Curtis at Wild Steed Worx.I have an 08 ridgeback and went for a ride today about an hour after returning saw fluid running down primary from the inspection door at the lower screw is there a gasket that could be bad or something else
