Where/how did you mount your speedo?That's kinda what I was thinking too, but to each their own. Going to a traditional set up with risers does give you the ability to adjust your riding posture a little though.
I have an '05 pitbull. My speedo is in the tank dash, so I didn't have to deal with that.Where/how did you mount your speedo?
If you can't find a mount for the risers, I would surely think someone makes a handlebar clamp.Where/how did you mount your speedo?
I see.... makes senseI have an '05 pitbull. My speedo is in the tank dash, so I didn't have to deal with that.
I'm unfamiliar with the pre-04. Do you have a tach? Where are the indicator lights? Post a pic if you can.I see.... makes sense
What if I switched the speedo out for one of those smaller digital ones? Would that work attached to the straight risers?If you can't find a mount for the risers, I would surely think someone makes a handlebar clamp.
Yeah, seems like it would work. There are dozens of companies making parts for choppers. Just do a little research. You will find something that works.What if I switched the speedo out for one of those smaller digital ones? Would that work attached to the straight risers?
This one has a clamp that you can purchase with it and it mounts directly to the risers, which then enables you to add the digital speedoYeah, seems like it would work. There are dozens of companies making parts for choppers. Just do a little research. You will find something that works.
Honestly, something for that shouldn't be hard to find. Like I said, I never had to deal with that, but surely something can be done. I'll look around and see if I can find something.![]()
I stand corrected. That does seem to be a hard part to find. Is your speedo 2 5/8"? If you can't find something, the digital may be the way to go.This one has a clamp that you can purchase with it and it mounts directly to the risers, which then enables you to add the digital speedo
I “think” is 2 1/2”. (Might be 2 5/8”).. I just need to call big dog Monday and start from there...I stand corrected. That does seem to be a hard part to find. Is your speedo 2 5/8"? If you can't find something, the digital may be the way to go.
BTW picture two is a West Coast Choppers CFL frame. Great look but the dumbest bike I ever rode. Do you know how hot that oil tank is. At red lights you have to sit on the fender to avoid burning your ass. Not warm, hot - flaming hot.I have a 2003 BD Chopper... what would I take to switch from the stock handlebar/speedo setup to mini-apes?
Something like this....
View attachment 70043View attachment 70042
Yes... I’m aware... I was simply looking at the bars on the bikeBTW picture two is a West Coast Choppers CFL frame. Great look but the dumbest bike I ever rode. Do you know how hot that oil tank is. At red lights you have to sit on the fender to avoid burning your ass. Not warm, hot - flaming hot.
I actually thought about suggesting that you may be able to make something for the guys that want to switch bars, but I didn't want to line you up for work that you may not want to do.I really haven't been following this thread, but if worse comes to worst I can probably make you something, to hold the speedometer. Let me know if you can't find anything
I make quite a few custom parts, and when asked, I do sometimes say no, or suggest a better option.I actually thought about suggesting that you may be able to make something for the guys that want to switch bars, but I didn't want to line you up for work that you may not want to do.
What’s the degree of rake on my 2003 chopper?I make quite a few custom parts, and when asked, I do sometimes say no, or suggest a better option.
