Evil Tharg
Hey Guys,
So, my 2010 Wolf now has just over 5,000 miles on it (I know, I know, I don't get much time to ride it) and sure enough last time I took it out the cam belt snapped. So far, so x-wedge right but the reason I mention it is that everything I ever read on here told me if you had the easy start cams fitted this wouldn't happen. Well my engine had the 545 easy start cams fitted right out of the factory, I have the build spec from S&S to prove it, so clearly that is not the case. It can happen anyway.
Just a heads up to any other Wolf owners out there, seems like even if you fitted the cams the belt will still break. So check those belts.
