I believe the bolts are 5/16 - 18 x 1" long. Grade 9 hex, use red loctite. I'm also gonna give Jim a call, wanted to get a new clutch pack.Started down the road and 3 bolts on the front pulley of the Karata backed out ( probably forgot to loctite them) almost lost the front pulley. The bolts are damaged. My boy brought me some tools and fixed it at a gas station and limped home. Need to get ahold of Jim a Karata and hopefully they will have parts available. That sucked
Paul,Started down the road and 3 bolts on the front pulley of the Karata backed out ( probably forgot to loctite them) almost lost the front pulley. The bolts are damaged. My boy brought me some tools and fixed it at a gas station and limped home. Need to get ahold of Jim a Karata and hopefully they will have parts available. That sucked
Good luck,I believe the bolts are 5/16 - 18 x 1" long. Grade 9 hex, use red loctite. I'm also gonna give Jim a call, wanted to get a new clutch pack.
Just called Jim and got the parts ordered. Not a cheap fixI believe the bolts are 5/16 - 18 x 1" long. Grade 9 hex, use red loctite. I'm also gonna give Jim a call, wanted to get a new clutch pack.
Hey, if you're going to go, Go BIGJust called Jim and got the parts ordered. Not a cheap fix
Always do, 2 mistakes made during the assembly no loctite and didn’t use my impact wrench to seat the bolts.Hey, if you're going to go, Go BIG
I was in meetings all day, I'll get mine ordered tomorrow. Glad you got what you needed..Just called Jim and got the parts ordered. Not a cheap fix
Cutting edges illusions they are out of OregonWho painted that red skull work? Is painter in SoCal?
Awesome chopper
