I was freaking out - the quote Mike has was no longer there.
Thanks for tips on spacers. I did the right side one correct - must've done the brake side wrong.
Eric - how thick is the shim ? I figure I would need at least 1/8" or 1/4". And I presume it would come with a right side spacer that is shorter by the same distance, right ?
It's hard to imagine that something else is so out of whack that I'd need to move the left adjuster that much differently than the right to achieve a straight tire. But even though I did the same # of turns on both sides, it seems to have shifted from angled toward the left at the front of the tire and riding the outside of the rear pulley, to the opposite now - belt is on the inside of rear pulley and tire angled to the right up front.
The problem is the belt is riding on the left edge of the front pulley. When I loosed the wheel and pushed the belt over on the front pulley by hand, there was tons of clearance from the tire. But when the tightened belt runs it moves the front left and hits the tire.
Today I'll move the left adjuster enough to pull that belt over and see how far it has to go.
Rick - that was the coolest and nicest way you could comment on how many times it's taken me so far........and of course it was worse than I posted. I wanted to save some face and spare y'all the pain of reading about my pain.
