mleach72
I found this on the Internet. I thought it was an interesting read.
That guy is awesome!I found this on the Internet. I thought it was an interesting read.
John, I have my 45 mounted to a SE 44mm manifold. Do you think that is a good combo, or do you think I should change to an S&S manifold? I realize a manifold change isn't going to make much difference, but I know it's the right combination of parts, gaining 1 hp here and there that makes an efficient engine.The manifold is the restriction. S&S originally had a sand cast intake manifold that was really bad. They finally came out with an investment casting, which is a huge improvement. Most Big Dogs have the good one.
The SE combo 42-45 intake manifold is IMO every bit as good as the S&S. Wouldn't pay to change. Just be sure it fits properly on the taller S&S engine.John, I have my 45 mounted to a SE 44mm manifold. Do you think that is a good combo, or do you think I should change to an S&S manifold? I realize a manifold change isn't going to make much difference, but I know it's the right combination of parts, gaining 1 hp here and there that makes an efficient engine.
Yep, it seems to fit perfectly as far as I can tell. I was told it was the manifold for the SE 44mm cv carb and made for the taller engines. Thanks!The SE combo 42-45 intake manifold is IMO every bit as good as the S&S. Wouldn't pay to change. Just be sure it fits properly on the taller S&S engine.
