Are those the bolts that hold the rocker boxes to the cylinders?Could try to tighten head bolts.
Yes. Bolt #44 It may buy you some time. Otherwise you'll have to replace the gasket.
Use a 12 point socket for the best fitment.I first need to obtain a socket that'll fit on the Bolt 44 heads, thanks
1/2" 12 point is the proper socket for S&S, Ultima, TP, Stock Harley .I first need to obtain a socket that'll fit on the Bolt 44 heads, thanks
10, 20, and 1/4 turn is NOT over torquing. Equates to 38 ft. lbs. Cometic specs is 42 ft. lbs. on S&S and others.Another variable would be something like this: Over torquing does not help. This is now a 'hydraulic path' no matter the squeeze. I'm assuming age here. Oil can be thinned to one millionth of an inch, so the wrinkle is still a squeezed down gap. Remember, heat cycle times years of never being torn down says the original paper is finally done.
Empirically speaking, I buy just the rocker top gaskets, the head gasket, tube orings, and two exhaust gaskets. A week later the base gasket takes a shit. Cost me $60 bucks for just the gaskets. Go back to the dealer, a counter guy says there is a top end kit for $95 bucks that covers both cylinders. I buy that kit, replace the one base gasket that is leaking, using a new head gasket from the kit. Get a phone call again, now the rear base gasket is leaking.
Moral of the story... the intake is off, the head steady is off, the tank is off, tear it ALL down once. Paper fresh both cylinders, or chase the leaks one at a time like I did. No doubt I learned the hard way. Also, those old flattened down [memory crushed] orings can bounce the tubes tighter and the top end is now oil tight with all new gaskets and rubber.
Signed,
NOLTT (no one listens to turtle)
Turns out it's the rocker box gasket that's leaking so going to replace them both and that's an easier job than if it was gasket #59.A related tidbit would be to mention proper warming up of the engine before performance demands. Don’t move it until the fins are too hot to touch. I don’t have science or research to support that, but when following that advice, I haven’t replaced a head gasket since.
I had the same problem and I ordered a top cylinder gasket kit and it fixed the problem. I have a extra one if you need it. call me at 434-483-1362,and maybe I can hook you up.I noticed on the left side of the battery/electronics cover there was some oil drops.
The only source of any leaking that I can see is around fins 9 & 10 (counting down from the top) on the rear cylinder.
Any input/suggestions would be helpful, thanksView attachment 68659
Thank you for the offer but I already ordered oneI had the same problem and I ordered a top cylinder gasket kit and it fixed the problem. I have a extra one if you need it. call me at 434-483-1362,and maybe I can hook you up.
