phatchopper300
I just wanta ride
can the engine light come on if engine oil is low
Do you need a service manualOk will check both with it being efi can I change idle and for o2 sensors just take off and clean. New to efi
He is asking about the Check engine light, not oil light.unplug the wire on the sensor, light should go out .
if not , look for the sensor wire bare somewhere (touching ground).
If it goes out , then check actual oil pressure while running.
Its either the oil pressure sensor , or actually low, low oil pressure
Can you show a picture of where the tappet screen is locatedThanks bigdogbro1 will check.......very frustrated now couldn't get program to read my cable and was very difficult for the serial port to be inserted into the ECU frame was in the way Had to move a lot around to insert serial port. I will check tapped screen tomorrow. The red engine light comes on about 15 sec after turning key with out turning over engine. Same when turn engine over..... Just got bike about month ago no issues had many long rides and then Sunday 15 min into ride engine light came on?........????.?.?.
Great picture thank you very much, when I take it out is there a special way to clean it never did this before just don't want to make something worseThis is where the screen is located. Just unscrew the cap and pull out the spring and screen.![]()
Sent from my SM-N975U using Tapatalk
