Primary gasgets -Help
Patrick
Putting primary back together n dealer said I need two small dime size gasgets also for my 02 pitbull primary.
I am unable to figure out where these go.
Thinking they are not for my primary which is early softail primary I'm thinking. See photos
Sent from my SM-J737T1 using Tapatalk
roadie1389
Nope. Not for this Primary. If you are only doing the outter, you have the main gasket, one for the inspection cover and an o-ring for the derby cover.
roadie1389
I think there are 2 kits. I think those are for a midcontrol type primary. I am not 100% sure. But the inner only had 1 oring to engine, starter shaft seal and main shaft seal.
Those are the primary stand offs ! They go on in between the inner and out primary post. Between the inspection post.
Patrick
Ok so do I need to RIP it back apart n put in or can I run without it?
Well imo I wouldn’t go tearing it back apart for this, not worth the trouble, Unless it is leaking fluid. Those gaskets go in between the 2 post that mount the inner to outer primary together around the inspection cover. It’s your call
Patrick
Thanks I was dreading ripping back apart. Horrible spun bearing noise I heard was compensator gone bad...thank god was only that. You guys know if primo rivera has shims for clutch still? Heard they were not really in business anymore.
Lastly. What jets. R u guys running and have I messed w air bleed jet?
