Paint Saver removal Tool
I got the paint saver ring from Mr Wright and getting ready to do the job , missing only the removal tool , read forum has 1 running around ...
Can someone let me know if you have 1 available?
Thanks in advance
Unsprung
In the Potters hand...
Give it a chance to see if someone comes along and reads this who has one. Most of these guys are a good bunch and won’t mind helping you out.
You can use a big bolt that threads in the hole and put a nut on and lock it down and put a 3/4 Ratchet on the bolt head and twist it out.
I will have to use the same ring and cap , won’t that damage it or it would twist out easily with some torque ??
bigdog1rm
I tried the tool could not get it out on mine. I forgot to say use a washer and tape it up after you put the nut on the bolt then thread it in the bung and lock the nut down and then i use a 3/4 inch ratchet with the correct size socket to fit the bolt. Mine came out really easy.
pknowles
RETIRED
There was one guy on here that tried beating his out with a hammer and a chisel.
Dont think it ended well:oldhardlaugh:
