suspension
Garyzac
Hi...Im Gary living in Australia. Have 2007 Bigdog Mastiff. Not many of these bikes over here. So im trying to find out about the suspension on these bikes.
When i 1st start the bike, the blue high beam light comes on. Has this anything to do with the suspension sorting it self out to right hight
Regards Gary
Brew
Chances are is that your low beam might be burnt out, the bike is defaulting to the high beam setting. If you change out the bulb this should fix that issue. Welcome to the site... :cheers:
Garyzac
Thanks for reply. But the low beam works. I replaced the EHC wiring to updated one i got sent out from USA, could be a problem with that
francoblay1
The Spaniard
Regards Gary
Check this out: MEMBERS KIWIS & AUSSIES
Welcome from Spain. :oldthumbsup:
:chopper:
Yes, sorry i worded it wrong. Should of been air ride
Not an issue. It's just that semantics can matter when troubleshooting long distance.....lol.
Other than a couple of function circuits through the EHC to operate the air ride there is nothing else.
Garyzac
OK Thanks for reply. Seems nothing to worry about my end
Do you sell BIG Dog parts.?
Couldnt get em over here, have to send to US for them
Pity they didnt have a Big Dog Distributor over here, cool looking machine
Regards
Gary
pknowles
RETIRED
No i dont, what are the directions please
Regards Gary
Well Gary, with out rereading this thread and if you have the stock controls and electrical system:
Turn the key on... press start then use the high/low light switch to air up or down.
Garyzac
AHHHHH. That answer my 1st question why high beam light come on when 1st starting the engine. The air ride is adjusting its self. Thanks for that
Gary
pknowles
RETIRED
Gary
It wont adjust unless you turn the key on and then hit start then hit the high beam and it should pump up or low beam will let air out.
