Just my take on the black box, meaning, you have nothing to loose trying this. Pull the neg battery cable. Tighten/check the posi cable for integrity. Turn key on, step on brake pedal; pull brake lever; pull clutch in (if there is a safety switch); turn the winker switch left and right; flip the high beam on and off; toggle the kill a few times...
... Key off; neg battery cable back on; start bike. Short of pulling the black box, find the ground pin and sweep all the pins times 3 to empty each RAM in hiding, one thing at a time-in other words.
Capacitor on motherboard = Holds the last known RAM (temporary memory) vs. Startup.
Binary Speak = A computer bike starts at zero (0000) vs. ROM (read this if RAM is lost from a capacitor).
Startup = Good known value saved in capacitor starts bike. If a Signal [means the same as value] is out of range it means a no-start. A bad known signal is a no-start. Thus, ground the saved value that shows a no start scenario. No guarantee here, just walking up to a computer bike and see if RAM saves the day.
