Starter
88fan
Been sitting all winter. Went out turn the key on starter instantly tries to engage with key. No buttons pushed any ideas ? 2009 mastiff
Jwooky
Pull the green wire off the solenoid off till you figure it out so you don't burn it up.
Check the voltage on it while you are there.
wrench
pull the cap off the solenoid and see if the plunger is stuck in. they get gummed up and will stick in.. been there before. pull it out and clean with some brake clean.
88fan
Ok will do thank you for the help
wrench
I was sitting here thinking about your problem. and actually if the solenoid plunger is stuck in it would be turning over even with the key off. just like you can push a slam button in with the key off and it will engage the starter. anytime the plunger is pushed in till it makes contact the starter will engage. even with the key off. It could be a low voltage problem. just like the old chevy corvettes , if the battery was low it wouldn't suck the plunger back out and they would just keep turning over till you disconnected the battery. Actually the button wire is the only thing on the starter that has no power when the key is off. I would make sure it has a good charge showing 12 to 13 volts in the battery, if it does,and its not the starter button or button wire,,, then my best guess would be the jack shaft gear is stuck out on the ring gear and thats what is holding the solenoid plunger in so its making contact.. i would first disconnect the starter button wire on the starter. the lil blade plug in above the solenoid. then turn the key on and see if it still does it. if it does then, you know its not the button. then i would pull the solenoid cap and then the primary cover or jack shaft cover if its belt drive.. if anyone has messed with the handle bar controls it could be the button wire is shorted.. bout all you can do is start an elimination process by checking everything in order.
wrench
just because a battery tender is showing a solid green light does not mean it has 12 or 13 volts in the battery. Ive seen em show solid green and the battery only be at 10 volts.
wrench
if you unplug the button wire off the starter and the starter does not still engage when you turn the key on. hook a test light to the wire, it should only light when you push the starter button. I think you may find the wire is constantly hot,,,,, because the starter stops when you turn the key off and Its the only wire to the starter that loses power when you shut the key off......check the starter button and the starter relay too...
88fan
It does stop when I unplug the button wire
Every time I've run into this, it's because of a bad battery. The start solenoid, in the EHC is stuck in start mode. Put a new Deka battery in it, and before you hook up the cables to the battery, hold the positive and negative wires, for the EHC together for a few seconds before hooking them up. Rumor has it, that this will reset the EHC.
