Oil Leak at Rocker Cover Corners
29C06745-C184-45AB-9DB2-D491152D10AD.jpeg 387FFD28-3ECA-4580-9320-BC0D19345738.jpeg I had an annoying small oil leak on my 06 Mastiff around front and rear rocker covers at the corners after each ride. I bought some Ultra Black Gasket Maker, cleaned area with alcohol and used a nitrile glove/finger to smear it into the seams at the corners. Wiped off with a rag and let it cure overnight. I have rode the bike 2 times and the leaks have stopped. Probably a temporary fix but thought maybe someone else might find it useful.
what?
yes i had the same issue right side closest to the front. its hit or miss. i backed the bolts out a hair and then torqued them down again. it worked for a quite a while but now i can see a few drops here and there.
awg
That's good to know. Beats tearing down the rocker covers. Also go with the S&S head bolt covers. Much cleaner look. No set screw.
mleach72
View attachment 63005 View attachment 63007 I had an annoying small oil leak on my 06 Mastiff around front and rear rocker covers at the corners after each ride. I bought some Ultra Black Gasket Maker, cleaned area with alcohol and used a nitrile glove/finger to smear it into the seams at the corners. Wiped off with a rag and let it cure overnight. I have rode the bike 2 times and the leaks have stopped. Probably a temporary fix but thought maybe someone else might find it useful.
Wanted to give an update here. I tried this about a week ago. I have only been on a few short rides, but so far leak has stopped! Thanks 787!:old2:
