..I don't use the enricher at all, uaually three twist of the throttle and then hit the start button, mine fires right up. Then just keep it idled up for a couple of minutes.
I start mine the exact same way.
I was instructed by the dealer back in 05’ to give 2 pulls on the Throttle, enrichener up until the RPM climbs to and levels off at 2,500. I have been doing this for 25K miles and it has always served me well. I was told, low RPM lugging is destructive to the motor especially when cold. My enrichener is not adjustable. It’s ether up or down. It almost sounds like he is adjusting the idle adjustment screw.It is an enrichener not a choke. When used, you pull it up after the start button is pushed. This allows a little more gas through the carb to assist with starting. Some prefer to twist the throttle a couple times. On cold starts, I twist the throttle once, and use the enrichener. As soon as the bike starts, it needs to be pushed back down all the way. Leaving it up does nothing but foul the spark plugs. If your bike won't stay running after 30 seconds of fast idle with the throttle, your carb is not adjusted correctly, or you have the wrong jets in it.
Truth. That’s what I do. The colder, the longer. I think that’s the only thing that applies to that statement. Lol! Just saying.dunno the time , just use it until the engine tells me to quit.
your results may vary with the temperature.
That’s really cool! Where did you get it?I'll show you mine, if you will show me yours.
What's the coldest you've ever started it in? (given location=FL)Never use it just two twist and go.
That’s awesome man!!!That’s really cool! Where did you get it?
I have to transfer it to the new motor. But this is it. Joker Machine “Jester”.That’s awesome man!!!![]()
I totally concur with the low-rpm lugging, or being destructive.... it may "sound cool" to some, but it's bad JuJu on a v-twin ring set.I was instructed by the dealer back in 05’ to give 2 pulls on the Throttle, enrichener up until the RPM climbs to and levels off at 2,500. I have been doing this for 25K miles and it has always served me well. I was told, low RPM lugging is destructive to the motor especially when cold. My enrichener is not adjustable. It’s ether up or down. It almost sounds like he is adjusting the idle adjustment screw.
36°F ambient outdoor tempWhat's the coldest you've ever started it in? (given location=FL)
Temps here dip into the low-40's and mid-30's, especially late night/early morning during Bike Week, even if the it reaches the hi-60's or low 70's during the day. Ive had more than one cold ride home at 4 am...lolWhat's the coldest you've ever started it in? (given location=FL)
In those temps I'm fine, 30 degrees and below is where the starting difficulties beginTemps here dip into the low-40's and mid-30's, especially late night/early morning during Bike Week, even if the it reaches the hi-60's or low 70's during the day. Ive had more than one cold ride home at 4 am...lol
