It says New S&S 124 in Florida.
https://treasure.craigslist.org/mpo/d/super-sidewinder-plus-124-ci/6719223667.html
ZERO MILES!!!!!!!!!!!! NEW NEW NEW... out of the crate.
This is not to be confused with the standard Sidewinder, this is the beefed up version from the factory (MSRP $9500).
S&S 124" polished finish
Engine patterned from S&S Pro Stock 160" record-setter. Designed to replace stock Harley-Davidson® Evolution® big twin engines in 1984-'99 chassis. Also used for new builds and in American Iron Horse Big Dog, Saxon, and many other bikes.
This is a single cam design engine which has a similar configuration to stock, it's just bigger and badder.
Utilizes Hi-Performance crankshaft featuring 1.5" diameter pressed-in crank pin for superior strength
Massive 4-1/8" bores with a stroke of 4-5/8"
High-performance oiling system, high-flow cylinder heads and added cooling fins are state-of-the-art for optimum horsepower and torque
Includes installed electric compression releases
124" Dyno tested at 130+HP at the rear wheel
Evo-style mounting
Features S&S Super G carburetor
Includes S&S 640G camshaft
Super Sidewinder Plus/31-0024L
Comes with MSO and manual.
Will fit HD 96" frame or larger.
May consider cash and trades.
Evo-style mounting
