Clutch trouble please help
tilemaster
my 2004 pitbull on the clutch pressure plate the 4bolts that go down onto bolts 1 of them just keep spinning and won't loosen can someone give me an idea on how to get that to loosen please u can call John on (386)-338-8159 I would really appreciate if someone can please take 5 minutes out of there day to please call me and talk to me I would more than appreciate it u can call any time Now. Day or night. Thank u john
roadie1389
http://www.vtwinmfg.com/instructions/20/20-0516.pdf
It looks as if either the studs are stripped or the stand-offs are loose.
Nukeranger
Nukeranger
Welcome to the forum from Louisiana. It helps you get help quicker if you do an introduction but you don't have to. :chopper:
shansel88
If there is no access to the back of the bolt, to keep it from spinning, I would likely try to drill the head off the cap, on the front side, with a drill bit about the same size as the allen key, then it should pop off as you break through, and then you can remove the assembly.
Based off what I see and understand, that's my opinion, or what I would do, then I'd replace pieces as needed for re-assembly.
francoblay1
The Spaniard
Check THIS out. :oldthumbsup:
:chopper:
Unsprung
In the Potters hand...
Sometimes a little outward pressure on the plate and a fast drill or impact will get it off. Hand tools make it a little tougher. I tried calling earlier but your phone just rang.
