POLL - Which "EHC" and Why? Pros & Cons?
  • EHC
    Votes: 6 12.8%
  • ESC
    Votes: 9 19.1%
  • RIP
    Votes: 8 17.0%
  • Axel´s
    Votes: 17 36.2%
  • Other
    Votes: 10 21.3%
  • Total voters
    47
francoblay1
The Spaniard
AXEL´s EHC Futures. (see pdf. better to read)
Manual for the EHC4 and EHC58
You don´t like to read manuals? We too... However, it will take only 2 minutes of your time to read it and 10
minutes for the installation and you will have more fun with your new EHC :)
We wrote this manual for the EHC4 and the EHC58 models. Just connect the d - sub connector(s) to the
EHC. and screw it gentle. We suggest to fill the connectors with Di-electric grease before of the
installation what helps to prevent the connectors against moisture.
Additional connection cables at the EHC4:
+ 12V Input (red): This is the main cable from the battery to the EHC. A fuse in this line is not necessary but
we suggest to put a 25 Ampere fuse in the main cable cause the internal highside switches can heat up the
epoxy material up to more than 120 degree Celsius in the case of a short circuit, what might result in small
gaps in the potting compound and a lost of water protection.
Ground (black): This cable is connected to the frame. Pls. take care that there is no rust or paint on the
connection.
Comp. Relief (yellow): This output will open the decompression valves if the starter button is be pressed
and the starter solenoid is active.
Starter solenoid (green): This output switches the starter solenoid.
Horn (gray): This output is connected to the horn.
Adjustment of the different functions:
The EHC can be used in most circumstances without any modification. However, you can easily change a
few functions in the EHC without being a software specialist. Hust press the "horn" button while switching on
the ignition switch and you are in the "setup" mode. A one time flash will indicate the first option, what is the
"Show flasher" function. Just press the "right" button if you would like to activate it or the "left" button if you
want to switch off this function. After a press on a direction button you will come imediately to mode 2 what is
indicated with 2 flashes of the turn signals. The following options are possible:
Number of flashes
Mode Left flasher button Right flasher button Describtion
1 x Show flasher Off On
2 emergency flashes when
power on the box
2 x Flasher auto off Off On
The flasher will switch off
after 20 or 40 times
3 x Flasher auto off 20 flashes 40 flashes
Number of repeats when
"Flasher Auto" is on
4 x Brake light mode Only brake light
Brake light / rear light
combination
The rear light will glim with
40 % when the brake light
switch is not pressed
5 x Brake light flasher Off On
The brake light will flash 3
times before it will be
permanent on
6 x Head light off Head light on Head light off
The head light is only
activated when you press a
light button
7 x Start / Stop button Start / Stop unsecured Start / Stop secured
The starter button is
disabled until the "Engine
Off" button is pressed once
Your setting are stored after 7 times pressing a direction button. Your are done! ... it´s that simple... The EHC
will keep your settings after a power off. However, you can change the settings every time you want.
1 / 2
On the side of the EHC are 8 status led´s implemented which are indicated in the following drawing:
A flash of a status led will indicate an active output.
The EHC was developed for an implemenation in BD bikes. It should be installed by professional well trained
engineers only. We suggest you to use the implemented rubber damper in order to reduce unwanted
vibrations at the box and connectors. Please check your local regulations regarding the traffic light rules in
your country before of the use of the EHC on your bike. Please be aware that we are not responsible for any
hazards, damages or disadvantages due to the use of the EHC The electronicbox devices are registered
under the number DE54933725 WEEE as B2C device. We also declare that the EHC is conform to the CE
and ROHS regulations for the European market.
We tried to keep the functions of the EHC and this manual as simple as possible. If you have any questions
while the installation please don’t hesitate to contact us at: info@ elektronikbox.de
Technical specifications:
Dimensions: 100 mm x 50 mm x 25 mm
Material: ABS, cast with 2 K epoxy
Temperature range: -20 degrees C to +70 degrees C.
IP53 according to DIN EN 60529
Power supply: 8 - 20 volts
Current consumption in idle state: about 80 uA
Max. Power consumption during operation: 25 Ampere
Outputs: short-circuit protected, self-resetting
We wish you to have a lot of fun with your new EHC on your bike and of
course always Ride Safe!
2 / 2
Big D Florida
I went with the RIP-II...Easily installed, but wish I'd gone with another set up, to replace the headlight harness. No further issues, to date.
Texas_Rigid
I'll give your thread a bump Franco!:cheers:
My bike had an ESC when I bought it used. Not sure the mileage when it was put in there but for the 6 months it was in my bike it worked flawlessly. No start issues, no speedo going nuts, lights on every time. It was great........
But computers on a chopper? I couldn't live like that. So I gutted it all and old school chopper wired it. But we can't talk about that in this thread :oldnono:
Whatever works for you.
That's the beauty of America we have choices
Coolbreezin
Remove the brain altogether. It can be done. Chopper City Jacksonville, FL did mine. I have the main 40 amp and two 15 amp fuses.
knothead
Second Chance Customs
Both of my 04 ridgebacks have wireplus...one been on 8 years no troubles yet..other one been on 6 years no troubles yet....but like i said yet....cluster of bullshit in my opinion but that was the only option that i knew of in 2011...if and when it takes a dump both will have new backbone harness and Axel kit put in them...threatened to do it this winter but just left them alone for now...
Coolbreezin
Here is what Chopper City did for me. They removed everything and added a simple controller for the brake lights and such. I have had no electrical issues. The battery is a 420 amp lithium ion and Ive had no problems with it since Jan 2019. Now my battery is below my frame, so i an start on my seat.
BULL74
I used Dead One Customs ESC - in my 05 chopper- very happy no problems- liked their extra harness option upgrades which I went with also- 3 years later no problems- plus he owns and rides BigDogs
